access to DDR on Spartan 3E Starter Kit
keitheda
Newbie level 1
I have Xilinx's Spartan 3e Starter Kit which has onboard DDR memory.
I'd like to start using that memory, but have struggled to get a DDR controller working.
I've tried using Xilinx's Memory Interface Generator, and while the code compiles, the testbench is too complicated & requires an external function generator (which I do not have access to) and/or non-free chipscope. The interface is daunting to someone new to FPGAs as well.
I've also tried various ddr controllers at opencores --- most I can't get to compile.
Thanks
Keith
kel8157
Full Member level 2
oh, it's difficultl unless you are experienced in RTLs and hardware design. In FPGA arena, codes don't usually run out of the box like open source software.
zhj1985
Newbie level 3
do you use MIG007, I am doing with MIG007 and I am doing behavior simulation
