Accelerometer MMA7660 interface to 8051 and display values on LCD
jaideep1992
Newbie level 1
Newbie level 1
Hello everyone
I am Jaideep pursuing Btech final year.
Currently i am doing my project titled "Vehicle Tracking and Accident Alert System"
It works with an acceleration sensor MMA7660 and depending on values obtained from it, the tilt is measured and accident is detected
Currently am facing projects in interfacing MMA7660 to 8051 since some Garbage values are coming on LCD
Here is my code:
sda equ P3.6
scl equ P3.7
org 00h
acall init
sa:
mov a,#98h
acall startc
acall send
acall mack
jc sa
amr:
mov a,#07h
acall send
acall mack
jc amr
am:
mov a,#09h
acall send
acall mack
jc am
start:
mov a,#98h
acall startc
acall send
acall mack
jc start
rax:
mov a,#00h
acall send
acall mack
jc rax
rby:
mov a,#01h
acall send
acall mack
jc rby
rcz:
mov a,#02h
acall send
acall mack
jc rcz
sar:
mov a,#99h
acall rstart
acall send
acall mack
jc sar
acall recv
acall ack
mov r0,a
acall recv
acall ack
mov r1,a
acall recv
acall nak
mov r2,a
acall stop
mov a,#38h
acall cmdwrt
acall delay
mov a,#0eh
acall cmdwrt
acall delay
mov a,#01h
acall cmdwrt
acall delay
mov a,#06h
acall cmdwrt
acall delay
mov a,#80h
acall cmdwrt
acall delay
mov a,#'X'
acall datawrt
acall delay
mov a,#81h
acall cmdwrt
acall delay
mov a,#'='
acall datawrt
acall delay
mov a,#82h
acall cmdwrt
acall delay
mov a,r0
acall datawrt
acall delay
mov a,#86h
acall cmdwrt
acall delay
mov a,#'Y'
acall datawrt
acall delay
mov a,#87h
acall cmdwrt
acall delay
mov a,#'='
acall datawrt
acall delay
mov a,#88h
acall cmdwrt
acall delay
mov a,r1
acall datawrt
acall delay
mov a,#8bh
acall cmdwrt
acall delay
mov a,#'Z'
acall datawrt
acall delay
mov a,#8ch
acall cmdwrt
acall delay
mov a,#'='
acall datawrt
acall delay
mov a,#8dh
acall cmdwrt
acall delay
mov a,r2
acall datawrt
acall delay
jmp start
cmdwrt:
mov p1,a
clr p2.0
clr p2.1
setb p2.2
acall delay
clr p2.2
ret
datawrt:
mov p1,a
setb p2.0
clr p2.1
setb p2.2
acall delay
clr p2.2
ret
delay:
mov r3,#0c8h
bck1:mov r4,#64h
bck:djnz r4,bck
djnz r3,bck1
ret
init:
setb sda
setb scl
ret
startc:
setb scl
clr sda
clr scl
ret
rstart:
clr scl
setb sda
setb scl
clr sda
ret
send:
mov r7,#08
back:
clr scl
rlc a
mov sda,c
setb scl
djnz r7,back
clr scl
setb sda
ret
ack:
clr sda
setb scl
clr scl
setb sda
ret
mack:
setb scl
mov c, sda
clr scl
ret
nak:
setb sda
setb scl
clr scl
setb scl
ret
recv:
mov r7,#08
back2:
clr scl
setb scl
mov c,sda
rlc a
djnz r7,back2
clr scl
setb sda
ret
stop:
clr scl
clr sda
setb scl
setb sda
ret
end
Please help
