AC(Sine) Signal Amplifier
bragas
Newbie level 5
Newbie level 5
Hi All,
I have a 1V 50kHz sine signal source and i want to amplify this signal to 50V 1A sine signal source using BJT's. Can you suggest me an amplifier circuit, which topology is suitable for this amplification? Thanks.
50W Class A Darlington will be ~ 60% efficient with transformer or L with C coupling, tuned to f. Choose Q for 50R.
... but this is distorted.... due to variation in hFE with I. So depends on needs.
thus use gain 50x and complementary x1 buffer. Does it need to be 50R output impedance? if so then V+=100V
For low distortion use 2 stage complementary cascode with feedback to control gain and linearity. GBW is only 500kHz.
Size heatsink and cpu fan accordingly.
Build this
Or simply by the OPA541.
