AC mains measurement
francis29
Member level 5
India
What is the best circuit for AC mains(230V) measurement. The circuit should have output voltage swing between 0-5V for microcontroller input.
If you are not experienced with working with mains- level voltages, the best is to use a small step down transformer. Let's say 230 to 6 volts.
Then with an opamp, make a precision rectifier. Use a resistor divider afterwards to lower the voltage such that the sinewave peak is lower than the 5 volt microcontroller supply. About 20% lower should provide margin for high line conditions.
what is the rating of transformer?? it is just for sensing right?? so how much small i can make it??
I built my own house voltage monitor using an inexpensive 'wall wart' type transformer, 7VAC. It drives a simple DC supply. The entire circuit draws less than 100mA. It has a 3914 IC which lights one of 10 led's.
i think you can get hall sensors specifically for mains measurement too.
if you are sensing for mains with a transformer and dont need to draw current as such, you still need fairly some size because of the build up of magnetising current.
