Register Log in
Ac load current detection
sareehy
Junior Member level 1
Hi All,
I want to detect an ac load current if exceed a certain value
(eg 0.5 A) and then turn buzzer and led on .
Any suggestion ?
Regards 🙂
sanjue
Newbie
This is a better solution. There are two solutions: isolated and non-isolated. I recommend the isolated solution because of security.
Use a current transformer to collect the current in the loop, and then convert the current output by the current transformer to a voltage through a resistor, and then simply use a diode to rectify.
If you need precision, use the RMS chip directly.
At this time, you get a Voltage signal, this voltage signal can be compared with the reference voltage through a comparator, and then the output of the comparator is connected to a BJT or NMOS to drive the buzzer
KlausST
Super Moderator
Staff member
First you need to define
* the current ...instantaneous, true RMS, rectified average, what filtering method
* and define the waveform...frequency, sine, with or without overtones.
* the output signal timing .... referenced to the input signal
Klaus
sareehy
Thank you all for reply ☺
The ac load is 220v/50 hz water pump .
KlausST
Super Moderator
Staff member
I assume there are ready to buy solutions.
But if you want to uild it on your own:
* most probably you want to transform the AC current into a DC voltage signal
* then blank out effects of inrush current, pump start current
* add some hysteresis
* add some protection in case of errors, like huge overcurrent when a short circuit happens.
Consider:
* isolated or not
* what power supply
Klaus
treez
Advanced Member level 5
cambridge
LEM do some good solutions for AC mains current CSTs
Also there are hall sensors by allegro.
Toggle Sidebar
