Mohamad Syazwan
Newbie level 3
- Joined
- May 16, 2014
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 31
Can someone help me with the code
I already have the hardware and code it with arduino
but i want to try it using pic16 using mikroC or mikrobasic
can someone help me regarding the code
this is my schematic diagram that i'm using
this is the arduino code
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 int AC_LOAD = 3; // Output to Opto Triac pin int dimming = 128; // Dimming level (0-128) 0 = ON, 128 = OFF void setup() { pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output attachInterrupt(0, zero_crosss_int, RISING); // Choose the zero cross interrupt # from the table above } //the interrupt function must take no parameters and return nothing void zero_crosss_int() //function to be fired at the zero crossing to dim the light { // Firing angle calculation : 1 full 50Hz wave =1/50=20ms // Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle) // For 60Hz => 8.33ms (10.000/120) // 10ms=10000us // (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65 int dimtime = (75*dimming); // For 60Hz =>65 delayMicroseconds(dimtime); // Wait till firing the TRIAC digitalWrite(AC_LOAD, HIGH); // Fire the TRIAC delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33) digitalWrite(AC_LOAD, LOW); // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC } void loop() { for (int i=5; i <= 128; i++){ dimming=i; delay(10); } }
