About SRAM-based FPGA
lahrach
Full Member level 3
Full Member level 3
Hi friends,
If I want to implement two designs in an SRAM-based FPGA at the same time, how can I do.
In other word if I have two VHDL codes: code _1 and code_2 how can I do to implement then on the same Time.
notes: I use ISE 11.4 and Xilinx FPGAs
Best regards
--------------LF
amraldo
Egypt
You have to create a bigger block that takes two instances of the 2 designs.
Amr
FvM
Super Moderator
Staff member
Advanced Member level 7
Bochum, Germany
"At the same time" obviously implies using different pins, so simply merge both designs, either in a single top entity or instantiate both top entities as components in a new design top.
velumuruganb
Newbie level 1
Newbie level 1
bangalore
Are the anyone can tell me , how to define and use Blind and buried vias in Allegro15.7?
