about spectre simulator
wonbef
Full Member level 3
Nanshan, Shenzhen
hi, all,
can you tell me how to use spectre simulator to complete the noise analysis under analog design environment in cadence? thanks in advance.
regards,
.noise analysis
output noise:
voltage, select the node you want to probe and the reference voltage.
input noise:
port or input voltage.
input=0
I think help in cadence can help you
in the ADE ,you can go to analysis ---
in the analysis section you find noise just left click on the noise you will get a new form for noise analysis ...enter the field and run a simulation...
firstly, many thanks to all above.
in spectre simulator, i always think the simulation result of noise analysis is uncorrect, and the input referred noise is very large. and in noise analysis option, if i select a port as the input, how to set the parameters of the port?
by the way, can you tell me how to analysize the input noise of a fully-differential amplifier?
thank a lot.
I also found that the input referred noise is incorrect.
somebody tell me that the testbench is wrong. it should be that.
yes, I also found there might be error about input referred noise when you simulating PPF's noise
