About program execution in 89c52
tapu
Full Member level 5
Full Member level 5
india
Dear All,
I have made a program of 6.7kb in keil.& loaded to AT89c52 by USB programmer.But it does not executed or run in actual board.Then I load another testing program of 2.1kb & run successfully which is according to same hardware.Here both programs are running in proteus simulation.please give reply.
Thank & regards
Tapu
Dear All,
Here This is program(6.7kb) of my project.which is alarm clock of 8 events per day with two types of ring. problom is that,this code runs on proteus simulation but does not run in actual board.As board is verified & tested with other program of 2.1kb. Please give reply.
( I use keil compiler).
Thanks & regards,
Tapu
#include <REG52.H>
sbit set=P1^0;
sbit mov=P1^1;
sbit inc=P1^2;
sbit rly=P1^3;
sbit ent=P1^4;
sbit e5=P1^5;//3rd e5
sbit e6=P2^3;//4th	e6
sbit e4=P1^7;//1st e4
sbit e3=P1^6;//2nd e3
sbit SDA=P2^6;
sbit SCL=P2^7;
sbit alarmset=P3^7;
void all_disp();
void time_set();
void alarm_set1();
void alarm_set2();
void alarm_set3();
void alarm_set4();
void alarm_set5();
void alarm_set6();
void alarm_set7();
void alarm_set8();
void alarm_chk1();
void alarm_chk2();
void alarm_ring_HI();
void alarm_ring_LOW();
void display_day();
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define Data_Port P0
sbit Lcd_rs = P2^0;
sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
/*sbit Lcd_rs = P3^5;
sbit Lcd_rw = P3^6;
sbit Lcd_en = P3^7; */
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_decimal2(unsigned char,unsigned char);
void Delay(unsigned int);
void del();
 bit f;
void Seg8_decimal2(min);
void Led8decimal2(hour);
void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
void I2C_Start();
void I2C_Stop(void);
void I2C_Ack();
void I2C_Write(unsigned char dat);
unsigned char I2C_Read();
 #define EEPROM_ID 0xa0
void delay_ms(unsigned int ms_count);
void I2C_NoAck();
void I2C_Clock();
void delay_us(unsigned int us_count);
void msdelay(unsigned int value);
#define DS1307_ID 0xD0
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
#define friday 6
DS1307_get(unsigned char);
void DS1307_settime(unsigned char, unsigned char, unsigned char);
void DS1307_setdate(unsigned char, unsigned char, unsigned char);
Send2lcd(unsigned char);
void Rtc_Write(unsigned char,unsigned char);
Rtc_Read(unsigned char);
void Rtc_rd_wr_sub();
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
unsigned int Rtc_add_wr,Rtc_add_rd;
unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
unsigned char i,j,a[10],cur=0;
unsigned char sec,hour,min,date,day,month,year,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn,yy,ahour,amin,asec,amin1,ahour1,ahour2,amin2,ahour3,amin3;
unsigned char amin4,ahour4,ahour5,amin5,amin6,ahour6,ahour7,amin7,ahour8,amin8,ahour9,amin9,amin10,ahour10,ahour11,amin11;
unsigned char count[8]={0x82,0x85,0x8a,0x8d,0xc2,0xc5,0xca,0xcd};
unsigned char rly_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec = DS1307_get(SEC);
min = DS1307_get(MIN);
hour = DS1307_get(HOUR);
date = DS1307_get(DATE);
day = DS1307_get(DAY);
month = DS1307_get(MONTH);
year = DS1307_get(YEAR);
min=Send2lcd(min);
hour=Send2lcd(hour);
day=Send2lcd(day);
Seg8_decimal2(min);
Led8decimal2(hour);
display_day();
void main()
Lcd8_Init();
Lcd8_Display(0x80,"RTC TESTING: ",12);
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"alarm can set:",14);
Rtc_Init();
//DS1307_setdate(0x04,0x11,0x11);
//DS1307_settime(0x16,0x00,0x00);
while(1)
all_disp();
if(day==friday)
alarm_chk2();
else
alarm_chk1();
if(!set)
time_set();
if(alarmset==1)
alarm_set1();
alarm_set2();
alarm_set3();
alarm_set4();
alarm_set5();
alarm_set6();
alarm_set7();
alarm_set8();
void display_day()
 if(day==0x01)
Lcd8_Display(0x84,"SUNDAY: ",7);
 if(day==0x02)
Lcd8_Display(0x84,"MONDAY: ",7);
 if(day==0x03)
Lcd8_Display(0x84,"TUESDAY: ",8);
 if(day==0x04)
Lcd8_Display(0x84,"WEDNESDAY: ",9);
 if(day==0x05)
Lcd8_Display(0x84,"THURSDAY: ",8);
 if(day==0x06)
Lcd8_Display(0x84,"FRIDAY: ",6);
 if(day==0x07)
Lcd8_Display(0x84,"SATURDAY: ",8);
void time_set()
all_disp();
cur=1;
while(ent)
if(mov==0)
while(!mov);
cur++;
if(cur==2)
cur=0;
else if(count[cur]==0x82)
if(inc==0)
while(inc==0);
hour++;
Led8decimal2(hour);
if(hour>=24)
hour=0;
else if(count[cur]==0x85)
if(inc==0)
while(inc==0);
min++;
Seg8_decimal2(min);
if(min>=60)
min=0;
hh=rly_hex(hour);
mm=rly_hex(min);
DS1307_settime(hh,mm,ss);
DS1307_setdate(dd,mn,yy);
void alarm_set1()
 Lcd8_Command(0x01);
 Lcd8_Display(0x84,"NOW set",7);
 Lcd8_Display(0xc0,"Regular schedule",17);
 Delay(65000);
 Delay(65000);
 Lcd8_Command(0x01);
 Lcd8_Display(0xc0,"Long ringl times",15);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_Display(0x80,"1:",2);
  Lcd8_decimal2(0x82,ahour);
  Lcd8_decimal2(0x85,amin);
  Lcd8_Display(0x88,"2:",2);
  Lcd8_decimal2(0x8a,ahour1);
  Lcd8_decimal2(0x8d,amin1);
  Lcd8_Display(0xc0,"3:",2);
  Lcd8_decimal2(0xc2,ahour2);
  Lcd8_decimal2(0xc5,amin2);
  Lcd8_Display(0xc8,"4:",2);
  Lcd8_decimal2(0xca,ahour3);
  Lcd8_decimal2(0xcd,amin3);
cur=0;
while(ent)
Lcd8_Command(0x0f);
Lcd8_Command(count[cur]);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
else if(count[cur]==0x82)			                    ///1st line of lcd
if(inc==0)
while(inc==0);
ahour++;
if(ahour>=24)
ahour=0;
Lcd8_decimal2(count[cur],ahour);
if(inc==0)
while(inc==0);
amin++;
if(amin>=60)
amin=0;
Lcd8_decimal2(count[cur],amin);
else if(count[cur]==0x8a)
if(inc==0)
while(inc==0);
ahour1++;
if(ahour1>=60)
ahour1=0;
Lcd8_decimal2(count[cur],ahour1);
else if(count[cur]==0x8d)
if(inc==0)
while(inc==0);
amin1++;
if(amin1>=60)
amin1=0;
Lcd8_decimal2(count[cur],amin1);
else if(count[cur]==0xc2)
if(inc==0)
while(inc==0);
ahour2++;
if(ahour2>=60)
ahour2=0;
Lcd8_decimal2(count[cur],ahour2);
else if(count[cur]==0xc5)
if(inc==0)
while(inc==0);
amin2++;
if(amin2>=60)
amin2=0;
Lcd8_decimal2(count[cur],amin2);
else if(count[cur]==0xca)
if(inc==0)
while(inc==0);
ahour3++;
if(ahour3>=60)
ahour3=0;
Lcd8_decimal2(count[cur],ahour3);
else if(count[cur]==0xcd)
if(inc==0)
while(inc==0);
amin3++;
if(amin3>=60)
amin3=0;
Lcd8_decimal2(count[cur],amin3);
Lcd8_Command(0x0c);
Delay(65000);Delay(65000);
 EEPROM_WriteByte(0x01, ahour);
 EEPROM_WriteByte(0x02, amin);
 EEPROM_WriteByte(0x03, ahour1);
 EEPROM_WriteByte(0x04, amin1);
 EEPROM_WriteByte(0x05, ahour2);
 EEPROM_WriteByte(0x06, amin2);
 EEPROM_WriteByte(0x07, ahour3);
 EEPROM_WriteByte(0x08, amin3);
 Lcd8_Command(0x01);
void alarm_set2()
ahour4=EEPROM_ReadByte(0x09);
 amin4=EEPROM_ReadByte(0x10);
ahour5=EEPROM_ReadByte(0x11);
 amin5=EEPROM_ReadByte(0x12);
  Lcd8_Command(0x01);
  Lcd8_Display(0x80,"5:",2);
  Lcd8_decimal2(0x82,ahour4);
  Lcd8_decimal2(0x85,amin4);
  Lcd8_Display(0x88,"6:",2);
  Lcd8_decimal2(0x8a,ahour5);
  Lcd8_decimal2(0x8d,amin5);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour4++;
if(ahour4>=24)
ahour4=0;
Lcd8_decimal2(count[cur],ahour4);
if(inc==0)
while(inc==0);
amin4++;
if(amin4>=60)
amin4=0;
Lcd8_decimal2(count[cur],amin4);
if(inc==0)
while(inc==0);
ahour5++;
if(ahour5>=60)
ahour5=0;
Lcd8_decimal2(count[cur],ahour5);
if(inc==0)
while(inc==0);
amin5++;
if(amin5>=60)
amin5=0;
Lcd8_decimal2(count[cur],amin5);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x09, ahour4);
 EEPROM_WriteByte(0x10, amin4);
 EEPROM_WriteByte(0x11, ahour5);
 EEPROM_WriteByte(0x12, amin5);
  Lcd8_Command(0x01);
void alarm_set3()
ahour6=EEPROM_ReadByte(0x13);
 amin6=EEPROM_ReadByte(0x14);
ahour7=EEPROM_ReadByte(0x15);
 amin7=EEPROM_ReadByte(0x16);
ahour8=EEPROM_ReadByte(0x17);
 amin8=EEPROM_ReadByte(0x18);
ahour9=EEPROM_ReadByte(0x19);
 amin9=EEPROM_ReadByte(0x20);
 Lcd8_Command(0x01);
 Lcd8_Display(0xc0,"short ringl times",15);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_decimal2(0x82,ahour6);
  Lcd8_decimal2(0x85,amin6);
  Lcd8_decimal2(0x8a,ahour7);
  Lcd8_decimal2(0x8d,amin7);
  Lcd8_decimal2(0xc2,ahour8);
  Lcd8_decimal2(0xc5,amin8);
  Lcd8_decimal2(0xca,ahour9);
  Lcd8_decimal2(0xcd,amin9);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour6++;
if(ahour6>=24)
ahour6=0;
Lcd8_decimal2(count[cur],ahour6);
if(inc==0)
while(inc==0);
amin6++;
if(amin6>=60)
amin6=0;
Lcd8_decimal2(count[cur],amin6);
if(inc==0)
while(inc==0);
ahour7++;
if(ahour7>=60)
ahour7=0;
Lcd8_decimal2(count[cur],ahour7);
if(inc==0)
while(inc==0);
amin7++;
if(amin7>=60)
amin7=0;
Lcd8_decimal2(count[cur],amin7);
if(inc==0)
while(inc==0);
ahour8++;
if(ahour8>=60)
ahour8=0;
Lcd8_decimal2(count[cur],ahour8);
if(inc==0)
while(inc==0);
amin8++;
if(amin8>=60)
amin8=0;
Lcd8_decimal2(count[cur],amin8);
if(inc==0)
while(inc==0);
ahour9++;
if(ahour9>=60)
ahour9=0;
Lcd8_decimal2(count[cur],ahour9);
if(inc==0)
while(inc==0);
amin9++;
if(amin9>=60)
amin9=0;
Lcd8_decimal2(count[cur],amin9);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x13, ahour6);
 EEPROM_WriteByte(0x14, amin6);
 EEPROM_WriteByte(0x15, ahour7);
 EEPROM_WriteByte(0x16, amin7);
 EEPROM_WriteByte(0x17, ahour8);
 EEPROM_WriteByte(0x18, amin8);
 EEPROM_WriteByte(0x19, ahour9);
 EEPROM_WriteByte(0x20, amin9);
 Lcd8_Command(0x01);
 void alarm_set4()
ahour10=EEPROM_ReadByte(0x21);
 amin10=EEPROM_ReadByte(0x22);
ahour11=EEPROM_ReadByte(0x23);
 amin11=EEPROM_ReadByte(0x24);
  Lcd8_Command(0x01);
  Lcd8_decimal2(0x82,ahour10);
  Lcd8_decimal2(0x85,amin10);
  Lcd8_decimal2(0x8a,ahour11);
  Lcd8_decimal2(0x8d,amin11);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour10++;
if(ahour10>=24)
ahour10=0;
Lcd8_decimal2(count[cur],ahour10);
if(inc==0)
while(inc==0);
amin10++;
if(amin11>=60)
amin10=0;
Lcd8_decimal2(count[cur],amin10);
if(inc==0)
while(inc==0);
ahour11++;
if(ahour11>=60)
ahour11=0;
Lcd8_decimal2(count[cur],ahour11);
if(inc==0)
while(inc==0);
amin11++;
if(amin11>=60)
amin11=0;
Lcd8_decimal2(count[cur],amin11);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x21, ahour10);
 EEPROM_WriteByte(0x22, amin10);
 EEPROM_WriteByte(0x23, ahour11);
 EEPROM_WriteByte(0x24, amin11);
  Lcd8_Command(0x01);
void alarm_set5()
ahour=EEPROM_ReadByte(0x25);
 amin=EEPROM_ReadByte(0x26);
ahour1=EEPROM_ReadByte(0x27);
 amin1=EEPROM_ReadByte(0x28);
ahour2=EEPROM_ReadByte(0x29);
 amin2=EEPROM_ReadByte(0x30);
ahour3=EEPROM_ReadByte(0x31);
 amin3=EEPROM_ReadByte(0x32);
 Lcd8_Command(0x01);
 Delay(65000);
 Delay(65000);
 Lcd8_Command(0x01);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour++;
if(ahour>=24)
ahour=0;
if(inc==0)
while(inc==0);
amin++;
if(amin>=60)
amin=0;
if(inc==0)
while(inc==0);
ahour1++;
if(ahour1>=60)
ahour1=0;
if(inc==0)
while(inc==0);
amin1++;
if(amin1>=60)
amin1=0;
if(inc==0)
while(inc==0);
ahour2++;
if(ahour2>=60)
ahour2=0;
if(inc==0)
while(inc==0);
amin2++;
if(amin2>=60)
amin2=0;
if(inc==0)
while(inc==0);
ahour3++;
if(ahour3>=60)
ahour3=0;
if(inc==0)
while(inc==0);
amin3++;
if(amin3>=60)
amin3=0;
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x25, ahour);
 EEPROM_WriteByte(0x26, amin);
 EEPROM_WriteByte(0x27, ahour1);
 EEPROM_WriteByte(0x28, amin1);
 EEPROM_WriteByte(0x29, ahour2);
 EEPROM_WriteByte(0x30, amin2);
 EEPROM_WriteByte(0x31, ahour3);
 EEPROM_WriteByte(0x32, amin3);
 Lcd8_Command(0x01);
void alarm_set6()
ahour4=EEPROM_ReadByte(0x33);
 amin4=EEPROM_ReadByte(0x34);
ahour5=EEPROM_ReadByte(0x35);
 amin5=EEPROM_ReadByte(0x36);
  Lcd8_Command(0x01);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour4++;
if(ahour4>=24)
ahour4=0;
if(inc==0)
while(inc==0);
amin4++;
if(amin4>=60)
amin4=0;
if(inc==0)
while(inc==0);
ahour5++;
if(ahour5>=60)
ahour5=0;
if(inc==0)
while(inc==0);
amin5++;
if(amin5>=60)
amin5=0;
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x33, ahour4);
 EEPROM_WriteByte(0x34, amin4);
 EEPROM_WriteByte(0x35, ahour5);
 EEPROM_WriteByte(0x36, amin5);
  Lcd8_Command(0x01);
void alarm_set7()
ahour6=EEPROM_ReadByte(0x37);
 amin6=EEPROM_ReadByte(0x38);
ahour7=EEPROM_ReadByte(0x39);
 amin7=EEPROM_ReadByte(0x40);
ahour8=EEPROM_ReadByte(0x41);
 amin8=EEPROM_ReadByte(0x42);
ahour9=EEPROM_ReadByte(0x43);
 amin9=EEPROM_ReadByte(0x44);
 Lcd8_Command(0x01);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour6++;
if(ahour6>=24)
ahour6=0;
if(inc==0)
while(inc==0);
amin6++;
if(amin6>=60)
amin6=0;
if(inc==0)
while(inc==0);
ahour7++;
if(ahour7>=60)
ahour7=0;
if(inc==0)
while(inc==0);
amin7++;
if(amin7>=60)
amin7=0;
if(inc==0)
while(inc==0);
ahour8++;
if(ahour8>=60)
ahour8=0;
if(inc==0)
while(inc==0);
amin8++;
if(amin8>=60)
amin8=0;
if(inc==0)
while(inc==0);
ahour9++;
if(ahour9>=60)
ahour9=0;
if(inc==0)
while(inc==0);
amin9++;
if(amin9>=60)
amin9=0;
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x37, ahour6);
 EEPROM_WriteByte(0x38, amin6);
 EEPROM_WriteByte(0x39, ahour7);
 EEPROM_WriteByte(0x40, amin7);
 EEPROM_WriteByte(0x41, ahour8);
 EEPROM_WriteByte(0x42, amin8);
 EEPROM_WriteByte(0x43, ahour9);
 EEPROM_WriteByte(0x44, amin9);
 Lcd8_Command(0x01);
 void alarm_set8()
ahour10=EEPROM_ReadByte(0x45);
 amin10=EEPROM_ReadByte(0x46);
ahour11=EEPROM_ReadByte(0x47);
 amin11=EEPROM_ReadByte(0x48);
  Lcd8_Command(0x01);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour10++;
if(ahour10>=24)
ahour10=0;
if(inc==0)
while(inc==0);
amin10++;
if(amin11>=60)
amin10=0;
if(inc==0)
while(inc==0);
ahour11++;
if(ahour11>=60)
ahour11=0;
if(inc==0)
while(inc==0);
amin11++;
if(amin11>=60)
amin11=0;
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x45, ahour10);
 EEPROM_WriteByte(0x46, amin10);
 EEPROM_WriteByte(0x47, ahour11);
 EEPROM_WriteByte(0x48, amin11);
  Lcd8_Command(0x01);
void alarm_chk1()
 ahour=EEPROM_ReadByte(0x01);
 amin=EEPROM_ReadByte(0x02);
 ahour1=EEPROM_ReadByte(0x03);
 amin1=EEPROM_ReadByte(0x04);
 ahour2=EEPROM_ReadByte(0x05);
 amin2=EEPROM_ReadByte(0x06);
 ahour3=EEPROM_ReadByte(0x07);
 amin3=EEPROM_ReadByte(0x08);
if(hour==ahour)
if(min==amin)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour1)
if(min==amin1)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour2)
if(min==amin2)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour3)
if(min==amin3)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour4)
if(min==amin4)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour5)
if(min==amin5)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour6)
if(min==amin6)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour7)
if(min==amin7)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour8)
if(min==amin8)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour9)
if(min==amin9)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour10)
if(min==amin10)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour11)
if(min==amin11)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
void alarm_chk2()
 if(hour==ahour)
if(min==amin)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour1)
if(min==amin1)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour2)
if(min==amin2)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour3)
if(min==amin3)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour4)
if(min==amin4)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour5)
if(min==amin5)
if(sec==asec)
alarm_ring_HI();
else
rly=1;
if(hour==ahour6)
if(min==amin6)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour7)
if(min==amin7)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour8)
if(min==amin8)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour9)
if(min==amin9)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour10)
if(min==amin10)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
if(hour==ahour11)
if(min==amin11)
if(sec==asec)
alarm_ring_LOW();
else
rly=1;
rly=0;
rly=1;
rly=0;
rly=1;
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=Lcd_rs=1;
Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e5=0;
P3=Lcd_t+0x30;
e5=1;
e6=0;
P3=Lcd_o+0x30;
e6=1;
Lcd_hr=hour%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e4=0;
P3=Lcd_t+0x30;
e4=1;
e3=0;
P3=Lcd_o+0x30;
e3=1;
/*********************************LCD HEADER FILE END*************************************/
/*********************************RTC HEADER FILE START*********************************/
DS1307_get(unsigned char addr)
unsigned char ret;
Rtc_Start();
ret = Rtc_Read(addr);
Rtc_Stop();
return ret;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
Rtc_Start();
Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */
Rtc_Write(0x01,mm); /* Write min on RAM address 01H */
Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */
Rtc_Stop(); /* Stop i2c bus */
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy)
Rtc_Start();
Rtc_Write(0x04,dd); /* Write date on RAM address 04H */
Rtc_Write(0x05,mm); /* Write month on RAM address 05H */
Rtc_Write(0x06,yy); /* Write year on RAM address 06H */
Send2lcd(unsigned char value)
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
void Rtc_Init()//lower order 256 bytes of the chip
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
if (CY==1)goto above;
CY=0;
Rtc_Stop();
Rtc_Read(unsigned char zig)// program to read from EEPROM
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
void Rtc_Start()// must for any operation on EEPROM
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
void Rtc_Tx()// program to send the device address, read/write address,data to be written
signed char i_rtc;
for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
CY=(d_rtc>>i_rtc)&0x01;
sda_rtc=CY;
scl_rtc=1;// clock is essential inorder to write or read
scl_rtc=0;// clk should be alternated
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
void Rtc_Rx()// program read the data from the EEPROM
unsigned char l_rtc;
sda_rtc=1;
for (l_rtc=0;l_rtc<=7;l_rtc++)
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
Rtc_Start();
here1:
d_rtc=Rtc_add_wr;// 0xd0 device address is passed
Rtc_Tx();
if(CY==1)goto here1;
again1:
d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
Rtc_Tx();
if(CY==1)goto again1;
    I2C_Start();               // Start i2c communication
    I2C_Write(EEPROM_ID);      // connect to AT2404 by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
    I2C_Ack();
    I2C_Write(eeprom_Data);    // Write the data at specified address
    I2C_Ack();
    I2C_Stop();                // Stop i2c communication after Writing the data
    delay_ms(1);            // Write operation takes max 5ms, refer At2404 datasheet
  unsigned char eeprom_Data;
    I2C_Write(EEPROM_ID);      // connect to AT2404(write) by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Ack();
    I2C_Write(0xA1);           // connect to AT2404(read) by sending its ID on I2c Bus
    I2C_Ack();
   eeprom_Data = I2C_Read();  // Read the data from specified address
    I2C_NoAck();
    I2C_Stop();                // Stop i2c communication after Reading the data
    delay_us(10);
  return eeprom_Data;          // Return the Read data
void I2C_Start()
    SCL = 0;        // Pull SCL low
    SDA = 1;        // Pull SDA High
    delay_us(1);
    SCL = 1;        //Pull SCL high
    delay_us(1);
    SDA = 0;        //Now Pull SDA LOW, to generate the Start Condition
    delay_us(1);
    SCL = 0;        //Finally Clear the SCL to complete the cycle
void I2C_Stop(void)
    delay_us(1);
    SDA = 0;            // Pull SDA  low
    delay_us(1);
    SCL = 1;            // Pull SCL High
    delay_us(1);
    SDA = 1;            // Now Pull SDA High, to generate the Stop Condition
void I2C_Ack()
    SDA = 0;        //Pull SDA low to indicate Positive ACK
    I2C_Clock();    //Generate the Clock
    SDA = 1;        // Pull SDA back to High(IDLE state)
void I2C_NoAck()
    SDA = 1;        //Pull SDA high to indicate Negative/NO ACK
   I2C_Clock();     // Generate the Clock
    SCL = 1;        // Set SCL */
    unsigned char i;
    for(i=0;i<8;i++)         // loop 8 times to send 1-byte of data
        SDA = dat & 0x80;    // Send Bit by Bit on SDA line
        I2C_Clock();         // Generate Clock at SCL
        dat = dat<<1;
        SDA = 1;                 // Set SDA at last
unsigned char I2C_Read(void)
    unsigned char i, dat=0x00;
       SDA=1;               //Make SDA as I/P
    for(i=0;i<8;i++)        // loop 8times to read 1-byte of data
       delay_us(1);
        delay_us(1);
        dat = dat<<1;       //dat is Shifted each time and
        dat = dat | SDA;    //ORed with the received bit to pack into byte
        SCL = 0;            // Clear SCL to complete the Clock
   return dat;               // Finally return the received Byte*
        while(ms_count!=0)
            delay_us(112);   //delay_us is called to generate 1ms delay
             ms_count--;
    while(us_count!=0)
         us_count--;
 void I2C_Clock(void)
    delay_us(1);
    SCL = 1;        // Wait for Some time and Pull the SCL line High
    delay_us(1);        // Wait for Some time
    SCL = 0;        // Pull back the SCL line low to Generate a clock pulse
