about offset voltage of op-amp
urian
Full Member level 3
hi,there
when we model the input offset voltage of op-amp with single-end input on inverting input,we always model it as a voltage source driving the noninverting input.
my question is that why we dont model it as a vltage source driving the inverting input?
Best regards
urian
urian said:
hi,there
Best regards
urian
Of course, you can do it. The result will be exactly the same. Start a calculation and compare the results.
    urian
@LvW
Exactly... the result would be same
@urian
The input offset voltage that you would insert in your circuit would be at inverting node of opamp.
So your equation will be (0-VIO)/R1 = (VIO-VOUT)/R2
this has the same effect as having a VIO( input offset voltage at non inverting terminal)->concept of virtual ground...
    urian
thx,guys
i thought they may be different before.now you clarify it.
Yes,it may be the habit of famous authors to put the input offset voltage at the noninverting node.
