about Hi-Tech PicC-lite
bjerkely
Member level 4
Turkiye
I'm currently using Hi-Tech PicC-lite , I compile my code with no error and use Proteus as simulator and they all work, everything is so fine in theory but when I try the same code in a circuit on bread board nothing seems to work,I can't even blink a LED .But When I use assembly instead of C , I get the LED blinking.
I can't guess the problem!!!
check TrisX
Mclr
and post ur code if this dont resolve ur problem
Errorless compiling does not mean your code is correct!
you may forgot something. or dont initialize correctly.
if you post your code we can help you better.
I just tried the code below on board,led on RB1 in continually ON,it's not blinking.
#include <pic.h>
#include <delay.h>
#include <delay.c>
unsigned char i;
void main(void){
TRISB=0;
for(i=20 ; i>=0;--i){
RB1=1;
DelayMs(500); /*500ms delay*/
RB1=0;
DelayMs(500);
while(1){}
Thanx in advance...
Hi bjerkely,
First:
DelayMs(unsigned char) get integer not grater than 255
you can try two of them with value 250.
Second:
in your code you do not define microcontroller (for examle)
#define _16F877
Third:
I dont remember how RB1 (RBx) used, so
i suggest try using " PORTB = 0x02; " instead of " RB1 = 1 "
Regards,
داود عامریون
    bjerkely
Thank you Davood. I'll try again with remarks in hand...Besides how can I define the crystal or the exact configuration word ??
( __config _XT_OSC & _WDT_OFF & _PWRTE_OFF)
check that your oscillator is running. If you didn't change default clock frequency setting, you should have 4MHz crystal for 500Ms to be correct
