about HBM model and simulation of HBM model and which tool used
vishal_meshram1087
Junior Member level 1
tell me the complete detail about HBM model in ESD and how to simulate and which tool i have been used.
HBM has different standards (targets) for an IC and is typically 2000V to 4000V simulating the charge that a human body can accumulate and then discharge into an IC by touching one of the pins. Modern IC assembly does not use humans in contact with the ICs but the HBM is still a major qualification requirement.
It is simulated by a current pulse to a maximum in 10nSecs and a slow decay over 100+ nSecs. Depending on the IC the current from the 2-4kV can be upto 2 Amps.
www.syncpower.com/datasheet/JEDEC HBM.pdf
