greatmarx
Junior Member level 3
My problem is that the mobile phone of our company can't pass the HB3 of DCS.
When we test the HB on the test point of the power PCL0,HB3 is under -40dB,But when we test it in darkroom ,the result is about -30dB.When we change the power to the PCL5,the power is lower ,but the HB3 was also -30dB.
The HB2 was very well,But the Harmonic of 5.3GHz is around -30dB and have the bandwidth of 200-300MHz,It looked like miscellaneous.
I have tried to change the power by series or parallel the RCL components. The result wasn't pass.
I also packaged the pcb board by Conductive fabric,only exposed the antenna point. But also failed.
The baseband chip is made of Taiwan company---MTK,the transever is AD6548 which is made of Analog Device.The PA is made of A Chinese company---RDA.
Regard
Yang...
Regard
Yang...
