kannan2590
Member level 4
in xilinx 9.1 i have used Single DCM to generate 120 MHZ frequency clock. from this i want to generate 5MHZ , 2.5 MHZ AND again 120 MHZ CLOCKS from this main 120MHZ clock. the raising edges of all the clocks generated should match .IS there any tecjnique in DCM itself so that we can generate 5MHZ , 2.5 MHZ clocks and 120 MHZ so that the raising edges of all the 3 clock generated are at the same instant.
