dongzz201
Newbie level 6
I encounter a problem when using cadence 614 .
i have a sub-circuit named SNV.cir & i have its spectre netlist. then i create a symbol using cadence symbol editor. i use this symbol to draw my top circuit using cadence schematic editor. when i want to simulate my circuit, the cadence fail to generate the netlist & report errors.
i found a method to fix this error : create the spectre view which copied from symbol view. then add a "model" property when instaninize this symbol & add the path link of the spectre netlist. i found this method from this forum. but unfortunately i can not get the right result. will i miss some the important steps ? or the other method exist ?
please give some hints !
