Aalmouti coding scheme question
shakeel006
Junior Member level 3
Pakistan
almouti code
Dear Sir
I downloaded Alamouti code from matlab central.I am unable to understand the following decoding part please explain.I have typed Q in comments for my question
% Decoding %
dh = sqrt(2)*[1 -1]/2; %Q: why this is used where it comes from?
%Computing the distances for the first symbol%
d11=((dh(1)-real(S(1)))^2+(imag(S(1)))^2); this is not distance formula between two points
d12=((dh(2)-real(S(1)))^2+(imag(S(1)))^2);
D1=[d11 d12]; %Distances for the received symbol
%Building the decisions vector for the first symbol%
for k=1:2
X1_dec(k)=((abs(dh(k)))^2)*sum(sum((abs(H)).^2)-1)+D1(k);
end
%Computing the distances for the second symbol%
d21=((dh(1)-real(S(2)))^2+(imag(S(2)))^2);
d22=((dh(2)-real(S(2)))^2+(imag(S(2)))^2);
D2=[d21 d22];
%Building the decisions vector for the second symbol%
for x=1:2
X2_dec(x)=((abs(dh(k)))^2)*sum(sum((abs(H)).^2)-1)+D2(x);
end
%The decisions!! We chose the little one%
[scelta1, posizione1]=min(X1_dec);
[scelta2, posizione2]=min(X2_dec);
If I can write in simple words what is ML detector it is as follows
arg min ( received signal - reference symbols ) ^2
where minimization is over all reference symbols.
I saw another example for BPSK which implemented ML decoding as follows.highlighted with bigger font
clear %clear matlab workspace
clc %clear command window
tic %intialize start time of simulation
M=2; % for BPSK we need only two symbols 0 or 1.
snr_db=0:12; % Range of 0-12 Dbs over which Pe will be calculated in this simulation
% LEN=[1e+6*ones(1,5) 1e+6*ones(1,5) 1e+6*ones(1,3)]; % number of bits transmitted i.e 10^6=100,0000.
LEN=[1e+6*ones(1,13)]; % number of bits transmitted i.e 10^6=100,0000.
srf=exp(j*2*pi*[0;1]/2); % reference signal
for k=1:length(snr_db)
bit_err=0;
for kk=1:LEN(k)
snr=10^(snr_db(k)/10); %SNR in real values
varn=1/(2*snr); %noise variance
data=randint(1,1,[0 M-1]); %random data generated
s=exp(2*j*pi*data/M); %signal tobe transmitted
n=sqrt(varn)*(randn(1,1)+j*randn(1,1)); %Complex gaussian distributed random data ???????
Another way of ML decoding in different way
x=s+n; % signal tobe transmitted
f=(abs(x*ones(2,1)-srf)).^2; % abs(( received signal - reference symbols )) ^2
[fmn,argd]=min(f); % for complex f=min(abs(f)),so [number index]=min(f)
dr=argd-1; %get the index
bit_err=bit_err+(dr~=data);%if the received is not equal to data then increment error count
end
poe_n(k)=bit_err/LEN(k); %no of errors/100,0000
poe_n_exact(k)=qfunc(1/sqrt(varn));
Please explain the difference between the two ML decoding implementations .
best regards
Shakeel
implementation + alamouti scheme
I have been seeing your topic unanswered for some time, so I wanted to write down something, may be I can help. I have found the code too long and disturbing as well, thats a strange way of coding. Why dont you try to write down your own codes in Matlab, the alamouti scheme should not be too complex to implement. If you want a document which tells how the alamouti scheme works I can post it here and you can implement it on matlab by yourself. Bye and sorry for not helping you with the code you posted here.
matlab code to check alamouti coding scheme
If you have a document which tells
how the alamouti scheme works so please post it here .if it is almouti IEEE paper.then i need to understand the matlab implementation .So if you simply the decoding.I shall be grateful to you.
I need to plot BER versus SNR curve for MRC and Almouti coding.
Shakeel
sorry but its an ieee paper that I have. If you fancy just take a look, if you dont already have it I should say that it is a good one telling how multiple antennas work. It also contains a BER plot for Alamouti, which may help you to double check your results as well.
Shakeel
Have a nice day..
Please dear , if you got the answer or the right code , let me know , coz I have same problem, I'll be thankful.
Thank you.
Regards
