A way to delay UART frame for approx. 200-300us.
intiCA
Junior Member level 2
Hello everyone,
I'm figuring out a way to delay UART frame for approx. 200-300us.
Are there ways to do that?
Could anyone suggest something on this matter?
BR
a 32kHz clock and an 8 bit shift register ser_in ser_out
Klaus
out of curiosity I did a search:
Now my solution is: an about 500kHz clock and MC14517 wired as 128bit shift register.
It should work well for 9600 as well as 19200 baud.
Klaus
Klaus
Klaus, could you just out of curiosity draw a sketch, how it would look like: the clock + MC14517, input, output and so forth.
First try it on your own. It´s rather sratight forward.
Show us your result.
Klaus
Klaus
it's not clear what did you mean by clock. Is there a specialized IC?
"Clock" is a rather common term in electronics, especially in digital electronics.
It is mainly defined by the frequency and voltage levels.. (there are also more detailed timing parameters)
Now I´ve told you the frequency: about 500kHz
and the voltage levels are given in the MC14517 datasheet.
Please understand that a forum can´t replace school.
If you are not familiar with the term "clock", then I must assume that you also are not familiar with proper power supplies, PCB layout, maybe voltage level converters....which you also need for your UART delay.
If this is the case, than I recommend to look for a person designing this project for you.
Klaus
Klaus
You must not assume anything. If I were you I wouldn't jump to conclusions. :thumbsdown:
Hi
You are upset because I don´t do your job - for free? Really?
I took my spare time for you to find a solution, I did an internet search, I gave you a part number.
I wrote more text than you. I gave, you took.
If this is not enough, then please rely on the (not yet given) answers of the other forum members.
Bye
Klaus
Hi
Bye
Klaus
yes, here you are right on all counts. Next time just refrain from something writing and let to answer other members which are less tired than you or so. :laugh:
I would be much obliged.
Cheers
Form both of us, the lazy one is you. Every one can recognize this.
You treat those who take effort to find a solution for your problem worse that the ones that don´t respond at all.
Thus I respect your point. Not responding to your posts in future does not have any drawback for me.
Klaus
