A very complex question (FPGA,YAMON,MCU)!
choloro_fell
Newbie level 3
HI all,
My respect to you all. I am a beginner in FPGA and still learning about FPGA.My system used Spartan 3 FPGA (XCS1500) and connect it thru AMD Au1100 MCU and also Blackfin DSP.I used YAMON as a bootloader to load OS to my target board.(thru VISION ICE EMULATOR)
My question is, how can the program/OS can be load to the target board.Is it the program/OS will be load to the MCP?(I am very confuse on how the MCP can control the FPGA).
next question is,how can i load the fpga program to fpga?thru visionICE or thru POD?
please help me,thanks:cry:
ewan
Junior Member level 1
For FPGA, I use an FPGA from xilinx. After finish my coding, ISE will synthesis it. iMPACT sw will be used to burn the .bit file into FPGA. We can look the system functionality by using Chipscope sw as provided.
