A T-junction Traffic Light Project (3-way)
mohnish1992
Newbie level 1
I need to make a digital logic circuit of a t-junction traffic light system using 74 series ic and breadboards. I got it working with the 4071 series ic but later I found out I can't use it. It has to be 74 series ic. If possible could someone draw a diagram and give me the full material list? Thanks in advance.View attachment Assignment_Trim2-2011-2012.pdf
andre_teprom
Super Moderator
Staff member
Brazil
I wish ask you if such project is a professional task, or if it is only for hobby.
That´s because commercial Trafic Light designs, have several others machine states than the classic sequence.
For instance, you should predict intercomunication between other commands placed on other squares, or placed on same corner.
Also, an alert flashing sequence must be implemented, in case of sensing a failture at some part.
