a sample program-USART (need help)
asham
Junior Member level 1
program usart
Hello!! i'm working on the program below...it is supposed to transmit numbers from the hardware to the PC hyperterminal...but it doesnt work due to syntax errors...i hav very poor c language knowledge...it would very helpful if anyone could help me to rectify the errors...there's an error especially in the 'for' statement....thanks....
#include<P18f452.h>
unsigned int i;
void main(void){
TRISC =0b10111111; //RC7(RX) as input & RC6(TX) as output
SPBRG =12; //baud rate =19200
TXSTA =0b00100100; //asynchronous mode, 8-bit data
//transmit enable, high baud rate select bit
RCSTA =0b10010000; //serial port enable,8-bit data
//continuous reception
for(i =30h; i<39h; i++){
//Transmit a byte
while (! TXSTAbits.TRMT); //Is the transmit shift register empty
TXREG = int ; //Write the data byte to the USART
while(1);
Hi
"XREG = int ; //Write the data byte to the USART "
int is a data type
you hade to declare your varable based on this data type at the start of program
like his
int data[9]={00,01,02,......08} //you put the data you need to transmitte in the bracts
and after that in your forr loop
TXREG = data //Write the data byte to the USART
Salam
Hossam Alzomor
Thank you...i made the changes you have told me but the syntax errors still exist...the error points to the line 'unsigned int i '...i tried removing this line and compiled the program but then the error moves to the next line...'void(main)void'please help....
