A reference device for Lightly Doped Drain (LDD) Layer
Rams94
Newbie
I am trying to use a p-type LDD layer for my design, but I cannot find any devices using the LDD layer in the library. I guess it is a derived layer.
I wonder if there is any device I can refer to?
FYI, I am using the TSMC 65nm process.
You may have to draw your own. There aren't many useful devices you can make. Poly is a hard mask so you can't make a LDD MOSFET. Too thin a layer, probably, to make a top gate JFET although you could make a back gate one (with front oxide meddling maybe).
Recommend you start with the mask fab Booleans to see how it's made, and if you're lucky your CAD platform has a utility to take a layout and give you mask logic layers to inspect.
It may be that a resistor is the best you can do. Hey, it's still a device.
