rakko
Full Member level 4
Does anyone know why in a flip-flop only setup is effected by clock speed but not hold? It seems to me that both setup and hold should be a fuction of clock speed. For example if the setup requirement = hold requirement = 1 nS in a FF, then, if the clock frequency is swepped from 500 MHz to 2 GHz, at 1 GHz or greater both setup and holds are going to be violated since the clock period will be shorter than setup/hold requirement of the flip flop. Doesn't this prove that they are both a function of frequency??
