A question about this OPA
wjxcom
Full Member level 5
Hi, all: this is a three stage OPA, now I have a question:
please look at the OPA in the attachment, In this OPA, when we design this OPA, we assume the third output voltage swing is 0.5v-4.5v.
But if we assume the output voltage swing is 0.5v-4.5v, how to confirm the voltage swing of the second stage? or say, what is the best value of the voltage swing of the second stage?
What's the power supply? Actually, the output swing of second stage should be (0.5+VthQ8) - (4.5 + VthQ8).
Hi, nxing: the power supply is VDD. In fact, the source of Q10,Q11,Q5,Q6 connect the VDD.
I think I can try to design this OPA by using the output swing of second stage is (0.5+VthQ8) - (4.5 + VthQ8).
Regards!
u can find a similar circuit in
Analog Integrated Circuit Design by Johns and Martin.
The chapter is "Adavanced Current mirrors"(p. 256)
in fact the last stage is a source foller, so the second stage outpiut is VGS high than the last stage
is the thired output stage source follower?
yes, the third part is a source follower, so the output swing of this stage will not reach 4.5v, I think it is not right. maybe much lower than 4.5V.
How about the power supply voltage? which process did you use? Maybe the bulk of your nmos can't be connected with the source.
