A QUESTION about the Cgd of the NMOS
poweric
Member level 5
while the NMOS opearate in the SAT
the Cgd is about 0
why ???
i dout know the reason
thank you for help
becoz there is no channel on the drain side in saturation region.hence no capacitance
    poweric
due to channel lenght modulation there is no channel at the drain side of MOS when it is biased in deep saturation region, so the overlap capacitance between gate and drain get added with oxide capacitance bcoz under gate oxide surface at drain end there is a depletion region which act as insulator and over all capacitance included gate drain overlap capacitance.
    poweric
An easy way to think about it is that now you have one plate (your gate), you have dielectric (SiO2) but your bottom plate (channel) is missing at drain side due to channel length modulation. That's why your Cgd now is nearly zero.
    poweric
