peterpops
Junior Member level 3
- Joined
- Mar 17, 2010
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Sweden
- Activity points
- 1,492
Hi!
I have a question about bandwidths.
The circuit I'm using is an analog multiplexer, ADG732BSUZ, and it has a typical "-3dB bandwidth of 18MHz"
My understanding is that this means that if I have a 18MHz signal of 1V inputed to the switch (ADG732BSUZ) the output will be around 0.5V, is that correct?
Now to the question, in the figure below I've marked in red a period of a signal, lets say 10MHz... however the green interval is a much faster change from LOW to HIGH voltage than 10MHz. So which one is it that is accounted for in the datasheet's 18MHz?
The reason I ask is that when I'm sending a signal through the multiplexer at 1, 2, 4, 6, 8, and 12MHz the output voltage is much lower than anticipated from the datasheet. And the higher frequency the more distorted the signal gets.
The signal is outputed by a signal/arb generator and measured by an oscilliscope
Or should the output be 0.708...V?
