The so called BALUN is balance-unbalance converter. In this case, the impedance to ground at the balance ports is 37.5 Ohm, but the impedance between both balance ports is 75 Ohm; at unbalance ports, one port is connected to gound, and the impedance between both unbalance ports is still 75 Ohm.
