A question about 8051 code
wjx197733
Member level 2
I download an 8051 code writed by from https://www.opencore.org, when I simulate the code, I find there has a error: the module ROM has three signals data1,data2,data3, the error message is these three signals has not been defined. in fact, but I do not understand where these three signals is from.
I think I can get help from here.
IanP
Advanced Member level 5
West Coast
If somewhere in the program you use constants such as Data1, Data2 and Data3 you need to declare them..
This can be done in the following way:
(values are chosen as needed)
Data1 EQU 01h
Data2 EQU 02h
Data3 EQU 03h
and from now on each time you will be using Data1, its code value will be 01h, for Data2 the value will be 02h and so on .. and they will reside in the program memory, in your case it is ROM ..
So, if you don't declare them you will have an error ..
Regards,
IanP
BTW, the link you have provided is dead ..
