ibrahim03
Full Member level 1
I am driving two stepper motors from the parallel port of the pc. The ratings of the two motors are 10V and 3A each. The computer sends pulses to FETs(z44n) which in turn drive the motor.
To give power to the motors i was using a computer power supply from a very old computer (386 or a 286 which i got from scrap). The rating of the power supply was 12V 8A and 5V 20A. Now I know that ideally this power supply should be giving 12V output but somehow it was giving 10.3V so I connected it directly with my motors without using any kind of converter(to convert from 12V to 10V). The motors ran fine for about 5 minutes but after that the power supply burned down (there was a lot of smoke and I turned it off immediately). After that I bought another old computer power supply of the same ratings. Coincidentally this power supply too was giving an output of 10.55V instead of 12V. So again I connected it directly without any converter and again the same thing happened, it ran fine for sometime and then the power supply burned down again.
Can anyone tell me what the problem is? Only the power supply burns.
