A problem about the setting of substrate in ADS momentum?
kingder2001
Newbie level 3
I have a problem with the setting of the ADS momentum. How should I set the substrate when to simulate a kind of PCB board with only toplayer and bottom layer? Whitch one will be better? Substrate1 or Substrate2?
Thanks a lot.
khouly
Advanced Member level 5
EGYPT
Re: A problem about the setting of substrate in ADS momentum
i think the substrate 1 is good for microstrip design , coz the bottom layer is a ground layer , so it good for this
khouly
yoonfatt82
Newbie level 2
Procedures for setting up the substrate of PCB in ADS:
1) Set your desired Permitivity, Er and thickness of your substrate. "Momentum>Substrate>Create/Modify>Substrate Layers"
Set these values in substrate layer (you can name it yourself) that placed in between freespace and ground.
2)Set the copper thickness value. "Momentum>Substrate>Create/Modify>Metallization Layers"
Set the metal thickness in '----Strip cond' layer that placed in between freespace and substrate layer that you named in substrate layer just now.
kingder2001
Newbie level 3
Thanks. What's the difference between the substrate layer and the layout layer in ADS momentum substrate?
