a hybrid 2 to 4 wire telephone circuit
polarized
Member level 4
Europe
2 - 4 wire hybrid
Hi all,
Is there an electronic circuit which can split the transmit and the receive audio which exist together on a fixed telephone line(a telephone pair) into two completely independent sections: transmit section and receive section ? I already have a couple of circuits, but would like to have more of them. I would like to use standard components which can easily be found, because some of the DAA special integrated circuits for this purpose of interfacing the telephone line are difficult to find.
Regards.
flatulent
Advanced Member level 5
Middle Earth
two methods
There are two general methods. One uses center tapped transformers. The other uses op amps. If you have these, you have the lot.
polarized
Member level 4
Europe
2 to 4 wire converter with operational amplifiers
Hi flatulent,
I have a couple of schematics, but they use the center tapped 600:600 ohm transformer. If its not a problem could you send me an electrical schematic of the 2 to 4 wire converter which uses operational amplifiers? And also how does the version of the 2 to 4 wire converter with operational amplifiers actually work?
Regards.
flatulent
Middle Earth
years ago
I saw the circuit in an application note years ago and do not remember the details. In general, there was some form of adding the transmitter signal to the receiver through a nulling route.
Reactions: GUSTA
    GUSTA
Borber
on third flor
Maybe you are looking for something like this:
Reactions: GUSTA
    GUSTA
alexg1485
hey guys i am also looking for 2 wire to 4 wire converter i wonder if you ever found it?
amjadali56
Full Member level 3
Earth
---------- Post added at 14:58 ---------- Previous post was at 14:52 ----------
Hi flatulent,
Regards.
Find an old dial-up modem that is not used anymore and steal its transformer.
Or take one from an old telephone answrering machine.
Or from an old speaker-phone?
FvM
Super Moderator
Staff member
Bochum, Germany
Unfortunately, the shown transformer circuit is not operating as a hybrid.
alexg1485
from my understanding 2 wire have transmission bydirectionally, and 4 wire have 2 balanced pair TX and RX. Shown schematic shows as one of the pairs is ground. Now is this still balanced. Another question: is the headphone jack is 2 considered as 2 wire?
FvM
Super Moderator
Staff member
Bochum, Germany
For a balanced hybrid, you can e.g. refer to the double-transformer hybrid. See: Hybrid coil - Wikipedia, the free encyclopedia
Please, notice, that a passive hybrid has also to keep some impedance relations to work correctly.
Here's a classical analog telephone hybrid circuit for reference. The complex termination and transformer winding ratios make it appear somewhat mysterious, but it's following a simple principle:
alexg1485
amjadali56,
Thank you. Your diagram shows one directional transmission. Whould it work for transmission bydirectonally? In settngs referring to of truks and telphone circuits and bydirectional voice trasmsion.? Thank you again.
foxbrain
Full Member level 2
Damas
the one on 12# is cool but what's the value of the transformer and the amplifier is 741?
FvM
Super Moderator
Staff member
Bochum, Germany
The internal resistor 620 ohm, so the transformer should be 1:1 for best hybrid opperation. 741 should work.
foxbrain
Full Member level 2
Damas
what do u mean by 1:1 ... as i know transformers are measured by its transfer from voltage to another otherwise if it is a coil so it's measured by henry.
FvM
Super Moderator
Staff member
Bochum, Germany
Really no clue? The specification seems self-explanatory in my view. Of course it doesn't fix all transformer parameters. But specifying just the windings ratio is quite common for audio transformers. 600 ohm:600 ohm would be another popular specification.
foxbrain
Full Member level 2
Damas
so here it is i have to use this equation : Z(impedence)=j*2*3.14*f*L
Z on each side is 680 ohm / f is frequency and it's about 3000Hz on the phone so L will be 36mH on each side of the transformer so it's to coils with a ferite between them and each coil is 36mH...
is this right???
FvM
Super Moderator
Staff member
Bochum, Germany
The impedance of the telephone line should be real (resistive) and frequency independent in a first order. So 30 mH transformer main inductance is surely inappropriate. The inductance should be large enough not to reduce the nominal 600 ohm value too much in the frequency band of interest (300 Hz - 3 kHz). L > 1 H is suggested.
foxbrain
Full Member level 2
Damas
that looks interesting and i'll try it as soon as i get the elements... but i would like to understand more about it : so u said that the impedance should be real (not imaginary) so how did mentioned to make it that big >1H what's the rule to make it real impedance instead of imaginary?
FvM
Super Moderator
Staff member
Bochum, Germany
The real impedance is set by resistors at both peers. The transformer inductance is effectively connected in parallel to the line impedance and must not be too low. 1 H transformer inductance results in a cut-off frequency of about 100 Hz with 600 ohm line impedance, so it' on the safe side.
fg = L/(6.28*R)
