hi guys,
well i spent a while (1 week) lookint at forums on this subject, i concluded that i need to see what happens with AR (0= cp; 1 -6=elipticalp;>Linearp) value on HFSS what i dont know, is how to plot this value
AR vs Frecuency Sweep? at wich angle of phy and theta?
AR vs Theta Angle (Mantaining COnstant Phy)
AR Vs Phy angle(Mantaining COnstant thetha)
i have seen on the forums that what you usually do is to plot AR vs main lobe angles, ok then can you be so kind to indicate wich angle should i leave constant on a microstrip antenna ( knowing that the main lobe is broadside the antenna)
PD = AR is a range of values if i do need to plot it against angles wich value should i take as a reference the max?
im colombian so sorry for mi english
do you guys have an example of antenna tutorial on HFSS that can ilustrate on this plz help me
