Re: digital aaudio - 4066 for audio switching ?
generally I recommend to look at tables or interactive selection guides at semiconductor manufacturers or distributors.
There you have the most recent and most detailed information - usually with direct links to the datasheets.
some say yes, other say no
as with most things "some say yes, some say no"
* is a [brand name] car a godd car?
* does fruit xxx taste good?
The 4066 isn´t bad .. and it isn´t very good....
There are other switches with dual supply, then you don´t need the DC offset (at input as well as output)
There are some with lower ON resistance, some with less distortion, some with less charge introduction...
It depends on your requirement.
Btw: I don´t call this "digital audio", because the audio signal is still analog.
Klaus
