A DFT Problem in Mbist -----Low faults coverage in Mbist!
bendrift
Member level 4
mbist
in my design ,i wrap all the ram with mbist.
after i insert dft and run atpg, i find the mbist decrease the faults coverage of the design.
here,i paste the report of tetramax and the mbist code for discuss :)
#faults testcov instance name (type)
51340 74.40% /vitcore/acs_datapath/acsram_fsm (vit_acsram_fsm_test_1)
10356 100.00% /vitcore/acs_datapath/acsram_fsm/btfram_ctl (vit_btfram_ctl_test_1)
10240 67.96% /vitcore/acs_datapath/acsram_fsm/ram_2 (vit_acsram_0_test_1)
5110 67.90% /vitcore/acs_datapath/acsram_fsm/ram_2/LRAM (dpreg16x80_0_test_1)
2970 71.73% /vitcore/acs_datapath/acsram_fsm/ram_2/LRAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_0_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_2/LRAM/dpreg16x80_inner (dpreg16x80_inner)
5110 67.90% /vitcore/acs_datapath/acsram_fsm/ram_2/URAM (dpreg16x80_1_test_1)
2970 71.73% /vitcore/acs_datapath/acsram_fsm/ram_2/URAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_1_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_2/URAM/dpreg16x80_inner (dpreg16x80_inner)
10236 67.94% /vitcore/acs_datapath/acsram_fsm/ram_4 (vit_acsram_1_test_1)
5106 67.87% /vitcore/acs_datapath/acsram_fsm/ram_4/LRAM (dpreg16x80_2_test_1)
2966 71.69% /vitcore/acs_datapath/acsram_fsm/ram_4/LRAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_2_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_4/LRAM/dpreg16x80_inner (dpreg16x80_inner)
5110 67.89% /vitcore/acs_datapath/acsram_fsm/ram_4/URAM (dpreg16x80_3_test_1)
2966 71.69% /vitcore/acs_datapath/acsram_fsm/ram_4/URAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_3_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_4/URAM/dpreg16x80_inner (dpreg16x80_inner)
10240 67.97% /vitcore/acs_datapath/acsram_fsm/ram_3 (vit_acsram_2_test_1)
5114 67.94% /vitcore/acs_datapath/acsram_fsm/ram_3/LRAM (dpreg16x80_4_test_1)
2966 71.69% /vitcore/acs_datapath/acsram_fsm/ram_3/LRAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_4_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_3/LRAM/dpreg16x80_inner (dpreg16x80_inner)
5106 67.87% /vitcore/acs_datapath/acsram_fsm/ram_3/URAM (dpreg16x80_5_test_1)
2966 71.69% /vitcore/acs_datapath/acsram_fsm/ram_3/URAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_5_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_3/URAM/dpreg16x80_inner (dpreg16x80_inner)
10240 67.96% /vitcore/acs_datapath/acsram_fsm/ram_1 (vit_acsram_3_test_1)
5110 67.89% /vitcore/acs_datapath/acsram_fsm/ram_1/LRAM (dpreg16x80_6_test_1)
2970 71.73% /vitcore/acs_datapath/acsram_fsm/ram_1/LRAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_6_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_1/LRAM/dpreg16x80_inner (dpreg16x80_inner)
5110 67.90% /vitcore/acs_datapath/acsram_fsm/ram_1/URAM (dpreg16x80_7_test_1)
2970 71.73% /vitcore/acs_datapath/acsram_fsm/ram_1/URAM/U_bt_sram (bt_reg_WE_WIDTH1_ADDR_WIDTH4_DATA_WIDTH80_7_test_1)
348 0.00% /vitcore/acs_datapath/acsram_fsm/ram_1/URAM/dpreg16x80_inner (dpreg16x80_inner)
rprince006
Member level 4
dft problem
There are many mbist algorithms, each covers different faults. You may try to implement more algorithms in your mmemory wrapper.
Such as, march 14N and checkboard, etc. Of course, you also have to consider
the cost and resources to implement them.
bendrift
Member level 4
mbist algorithms
I just mean that Mbist wrap decrease the whole design stuck at faults coverage not the memory test.
for the Mbist wrap have compare logic ,and compare logic was bounded at "111111" or '000000" ,so after insert dft ,atpg can not detected the stuct at faults of the compare logic. how can i do now ?
power-twq
Full Member level 6
dft ram
hello, perhaps you should use bypass signal bypass your ram micro in atpg test
mode.
bendrift
Member level 4
dft faults
i have by pass the signal before ram,but the mbist tie some signal at "000000' or "111111" for bist compare,it decrease the fault coverage!
zic
Newbie level 5
Generally we don't test the Bcon and please add no fault to them.
michealwolf
Junior Member level 1
Re: mbist algorithms
Yes, bound some point will decrease the converage.
