Nikolai
Member level 3
The following is the code im using to write a Demux. It is working fine.
But XST is issuing a warning :
Xst:737 - Found 8-bit latch for signal <O0>.
WARNING:Xst:737 - Found 8-bit latch for signal <O1>.
INFO:Xst:2371 - HDL ADVISOR - Logic functions respectively driving the data and gate enable inputs of this latch share common terms. This situation will potentially lead to setup/hold violations and, as a result, to simulation problems. This situation may come from an incomplete case statement (all selector values are not covered). You should carefully review if it was in your intentions to describe such a latch.
So is there a better way to write a Demux ? I have also tried using "case" and concurrent "when" statements but i keep getting this warning.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Demux_64 is
Port ( Input : in STD_LOGIC_VECTOR (7 downto 0);
Select_line : in STD_LOGIC_VECTOR (2 downto 0);
O0 : out STD_LOGIC_VECTOR (7 downto 0);
O1 : out STD_LOGIC_VECTOR (7 downto 0);
O2 : out STD_LOGIC_VECTOR (7 downto 0);
O3 : out STD_LOGIC_VECTOR (7 downto 0);
O4 : out STD_LOGIC_VECTOR (7 downto 0);
O5 : out STD_LOGIC_VECTOR (7 downto 0);
O6 : out STD_LOGIC_VECTOR (7 downto 0);
O7 : out STD_LOGIC_VECTOR (7 downto 0));
end Demux_64;
architecture Behavioral of Demux_64 is
begin
process (Input,Select_line)
begin
if (Select_line = "000") then
O0 <= Input;
elsif (Select_line = "001") then
O1 <= Input;
elsif (Select_line = "010") then
O2 <= Input;
elsif (Select_line = "011") then
O3 <= Input;
elsif (Select_line = "100") then
O4 <= Input;
elsif (Select_line = "101") then
O5 <= Input;
elsif (Select_line = "110") then
O6 <= Input;
else O7 <= Input;
end if;
end process;
end Behavioral;
library IEEE;
--library UNISIM;
entity Demux_64 is
end Demux_64;
begin
begin
O0 <= Input;
O1 <= Input;
O2 <= Input;
O3 <= Input;
O4 <= Input;
O5 <= Input;
O6 <= Input;
else O7 <= Input;
end if;
end process;
end Behavioral;
