A basic question on clock
ryang
Member level 2
In some documents, I read that
The module is designed to operate at 12 MHz using the free running (non
phase selected) clock.
What does the term free running clock mean? I am not very clear.
Does anybody give me some hint?
Thank you in advance:)
farhada
Advanced Member level 2
Nice, France
Free running means it is not locked into another source and it is not synchronized by any means.
Any crystal oscilator is a free running clock, but an oscilator with an outside source via PLL, is not.
The problem with free running clocks is that if you have 2 sources with the same frequency runing at 2 different oscilators, after a while, these 2 will get away from each other and are not synchronized. This can cause a lor of problems if you are dealing with datasharing and communication between the 2 in high speed.
Hope this helps a bit,
Best regards,
/Farhad
    ryang
