a bad tape-out experience about a bandgap voltage reference
liuyonggen_1
Full Member level 4
could someone help me?
tha attachment is the structure of bandgap voltage reference. the simulation result showed that the output is about 1.12v with 10ppm.
but when I measured it after taped out, the output voltage is about 0.7v.
the following will show you the performance of the elements.
the threshold voltage of the BJT is about 0.8v. its current gain is about 10 (very small). maybe, the matching between the resistance is bad.
could you explain it for me ? thanks a lot!
Re: a bad tape-out experience about a bandgap voltage refere
The structure of your bangap is wrong.
I don't think it can afford a 1.2V output voltage.
Did you try sweeping the Vdd to higher voltage?
the vdd is about 5.8v
yes ,i sweep the vdd to about 10volts, the output voltage is about 1.2v. but when continue to increase the vdd, the output voltage will also increase.
Added after 2 minutes:
could you explain it in detail? thanks a lot!
i think you can explain your structure first.
i think it's a basic voltage reference structure.
first you will check you circuit ,then you must simulate the circuit and check the DC operation point,at last .at last to solve the problems.
the simulation results shows that the circuit work normally. but the measure result shows as the above said.
