90s2313 and attiny2313
pkedvessy
Member level 5
90s2313
Hy all!
Till now, I used 90s2313, and now I want to use attiny2313.
The base problem is: how I can programme the new chip?
I used Fun-card programmer, with IC-Prog 1.05D to programming the 90s2313 chip, and I'd like to know, can I use it with the tinny2313?
Thank for your answer!
Added after 1 minutes:
Here is the programmer's schematic: https://www.serasidis.gr/circuits/avrprog/avrprog.htm
slavko
Member level 2
avreal programmer
Hi, you can use the same hardware with the AVReAl software, because the FUN card programmer doesn't support the tiny2313, look at here for the AVReAl programmer http://ln.com.ua/~real/avreal/index_e.html and in adapters sections look at FBPRG, good luck :D
ps: the bed side is that AVReAl is command-line program
