Jan 25, 2012 #1 G ggmssr Member level 2 Joined Oct 25, 2011 Messages 48 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 1,586 Can i put the same microcontroller code into SMD and DIP case. Code writen for DIP, can I put into PLC or TQFP ?
Jan 25, 2012 #2 U ud23 Advanced Member level 3 Joined Apr 20, 2011 Messages 926 Helped 185 Reputation 370 Reaction score 180 Trophy points 1,323 Activity points 6,138 yes you can use same code but you need to verify other package pin outs for your hardware connection.
Jan 26, 2012 #3 G ggmssr Member level 2 Joined Oct 25, 2011 Messages 48 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 1,586 If is DIP, dip have lower number of pins then TQFP, this say that that extra pins in TQFP not used. I think that this will work, I mean DIP to TQFP?
Jan 26, 2012 #4 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 ggmssr said: If is DIP, dip have lower number of pins then TQFP, this say that that extra pins in TQFP not used. I think that this will work, I mean DIP to TQFP? Click to expand... If the both package types are of the same model of 8051. Yes, it should work. And as long as the proper pinout connections are made to the device and the oscillator configuration is the same. BigDog
