89C51 serial programming HELPL...
hussain_kiet
Full Member level 5
Karachi, Pakistan
89c51 serial programmer
hi i am using AT89C51 uc with KIEL microvision 2 compiler i want to write to and read from serial port
i ve made the required circuit but still having problems (cant see the data written)
can anyone plzz tell me how could i write on serial port and how can i see the data written to serial port..??
this is my code
#include <reg51.h>
void sertx(unsigned char);
void main(void)
unsigned char z;
unsigned char aa[] = "MHWSQ";
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
while(1)
for(z=0;z<5;z++)
SBUF = aa[z];
while(TI == 0);
TI = 0;
89c51 programming
Your program is correct and you get the output on the serial window. But you need MAX 232 IC. Connect TX and RX of controller to MAX232 and connect MAX 232 to PC with a serial cable. Use hyperterminal to see the output. Your program will work.
connect max232 to 89c51
I agree with ckshivaram you cant connect cmos or ttl levels direct to RS232.
RS232 is also a physical protocol working with +-15V. So be careful as you can easily blow-up UART pins of mcu's if you connect them directly! Take a look:
https://www.lammertbies.nl/comm/info/RS-232_specs.html#phys
well i ve used max232 ic but still cant see the output on the hyper terminal..
when i will connect my circuit then the hyper terminal will directly show the output
or i have to receive the file...???
and when i receive the file it shows garbage value..
First of all you have to configure the communications options in ht. For example 8bit data, 1 stop, no-parity, 9600 b/s, etc and ofcource select the right port. This have to match with your configurations on the mcu exactly. If this is ok, the input is shown directly in the ht screen. (receiving garbage probably means wrong configurations)
Anyway you can always check with an oscilloscope the tx pin of your mcu before and after the max232, so you can easy verify the levels and frequency of the signal
hi. all the replyies are correct about serial communication and must be done before sending data. but there is some more thing. you must set the TI flag at the start of the program like I have corrected for you in your own code.
and beside this you can simply use printf instruction to send data to PC. like this:
printf ("MHWSQ\n");
hope that works.
Regards.
