8870 DTMF decoder Problem!
UroBoros
Advanced Member level 2
Cochin - India
8870 dtmf decoder
Hai
I am using 8870to decode a DTMF tone from a telephone line.
But the decoder always out a different value.
for 2 it outs 3
for 4 it outs 5
That means the LSB of the data line always come as 1.
I checked the line for any short or anything like that.
Any idea?
Anything to do with gain of 8870 that it outs error values?
I tries 270k and 470k as feed back resistor.No change?
suggessions please
picstudent
8870 dtmf
HI HAVE WORKED ON THIS DTMF DECODER LONG BACK.DIDNOT GET ANY SUCH ERROR EVER. BUT I REMEMBER THERE IS A PIN IN THIS CHI WHICH BECOMES HIGH WHEN EVER ANY DTMF SIGNAL OF ANY VALUE IS RECEIVED. I THINK U MUST BE TAKINHG IT AS UR LOWEST BIT. CHECK THE PIN DETAILS.
IF U STILL DONT GET LET ME KNOW
I WILL FIND OUT
    UroBoros
dtmf 8870
Can you show us the schematic?
ps. What did you use for Ringing, Hook up etc. from the line?
    UroBoros
decoder 8870
Hai
Schematic is not in softcopy now.Only in paper.
Now no ring detection is wired.
I have just connected the Delayed steering output pin (of 8870)to a input pin of MCU and polls it for a signal.
When that pin shows a high I am enabling the out enable pin of 8870 and reads the port.
regarding the DTMF 8870 schematic , it is the one showed in their datasheet.
thanks
picstudent
holtek 8870
Check if you have left any unused pins floating
    UroBoros
pins of dtmf decoder 8870
Hai
Thanks all.
The DTMF decoder CA8870 was faulty.replaced it and all ok.
Actually I didint suspect such a possibilty.
That chip was 3 years "old" in my junk box. It was working then .(3 years before).
Thanks to all
picstudent
ht9170 bug
DTMF DECODER ... safe and low cost ( verified ) from HOLTEK HT9170
