8086 Assembly language
shermaine
Newbie level 6
8086 assembly
basically, how to i write a asembly program displaying 5 digit random number on the five 7-segment LEDs and automatically incremented by one every second whenever pushbutton 3 is pressed. Pressing push button 4 shall alternately pause and continue the counting. Is there any sample program which i can have a look? Please advise. Thanks!
8086 assembly language
It depends mostly on the hardware you're using. Like what hardware, I/O ports and memory space, etc.
8086 assembly language programs
Well i have a code for generating the random numbers on 8085 trainer kit.
If you want that i can send it to you but it wont be much useful as most of the things depend on the trainer kit,or hardware that you are using.
    shermaine
8086 assembly kit
Could you please send it to me?
8086 assembly loop
What hardware are you using shermaine?
seven segment asm 8086
the code for a random numer generator
the main program consist of a simple loop to increment a byte counter.The counter after reaching FFh,become 0 again with one further increment and thus is alwyas a value between 0 and FFh.Whenever the user presses KBINT (rst7.5 interrupt in our trainer kit)the interrupt service routine fetches the counter value ,masks off the most significant 6 bits,displays the value (thus the number displayed is alwats 0,1,,2,3)and returns to main program which to update the counter value
main program
MVI A,0B; UNMASK RST7.5 INTERRUPT
SIM;enable interrupts
EI;intialise interrupt
XRA A
LOOP:INR A
JMP LOOP
now in my kit whenever kbint is presses it transfers the control to 8fbf mem location after executing the instruction at 3C
So at 8FBF we eneter JMP to some new location (say address 8820)
now at 8820H we writ
PUSH PSW ;for saving a counter
ANI 03 :to mask off the most significant 6 bits
LOOP: STA 8FF1 ;STORE CONTENT OF ACC TO ADRESS 8FF1
MVI B,00; LOAD REG B WITH 0(TO AVOID DOTS IN DISPLAY)
CALL UPDDT;(DISPLAY THE DATA AT ADDRESS 8FF1)KIT'S SPECIFIC FUNXN
POP PSW
EI
RET ;RETURN TO MAIN PROGRAM
ANY RANDOM NUMBER BETWEEN 0 AN 3 IS DISPLAYED WHENVR KBINT IS PRESSED.
thIS PROGRAM IS SPECIFIC TO A KIT BUT I THINK THE LOGIC WOULD BE CLEAR TO YOU.BUT THE CODING DEPENDS ON THE HARDWARE
increment variable 8086
My hardware is per attached. I need to construct an address decoding circuitry on an ISA adapter card for decoding the I?O devices. The I/O devices consist of five 7-segment LEDs, one 16-segment LED and eight push buttons. The 16-bit data bus is for data transfer, and I/O map for I?O devices. The I/O address for 16-segment LED is 300H-301H and I/O address for 5 x 7 segment LEDS is 302H-306H and I/O address for 8 x push button is 307H (D8-D15)
I need to do a auntomatic incremental counter ( how sould the program be like for this part)? A 5 digit random number shall be displayed on the five 7 -segnebt LEDs and automtically incremented by one every second whenever pushbutton 3 is pressed. Any one can advise me on this part's programming? Thanks!!!
