[SOLVED] 8051c 3x3mm Tiny MCU
mekitron
Junior Member level 3
Mehran Valley
iambozdar.com
Hello All,
I'm thinking to work on 8051c 3x3mm MCU. It'll be my first time to design a circuit to program such a small MCU. If anyone has already worked then it'll be great to give me a hand to start a bit easily. The most challenging part is that I want to plug the tiny MCU instead of soldering on a PCB because I have to solder it on another PCB to use.
Thanks,
Meki
I presume you are talking about a specific chip type? Doesn't it support in-circuit programming?
You'll get test sockets for any package, even "chip scale". Unfortunately the'll cost some 100 $.
Quite expensive! 8051c 3x3mm MCU supports in-circuit programming but I am not going to use it. I have deiced to use Freescale QE MCU.
