engg.embedded
Junior Member level 1
mcs51+project sensor
hi... im posting the ckt diagram. jus the main ckt of FP module and GSM module. The relay is a 5V relay and is activated and deactivated by microcontroller through pin P1.6... I have made this ckt and used two different MAX 232 ckts. The FP module ckt is working fine, bt again the GSM part is not transmitting any thing. There is no voltage on pin 3 of the DB9 connector(with is connected to the GSM module)...
Ny help???
Thanks
Ny help???
Thanks
