shivachellam said:now i am started to learn about atmel89c51 plz anyone give idea about atmel89c51 and what r the step to achieve good programing in 89c51 thanks
srikanthsamaga said:Just reading Mazidi book is not enough, you should practice the examples given in that practically, and then write small and simple codes on your own.
The 89C51 series microcontrollers need expensive programmers, So I suggest you to buy a 89S5x (x may 1,2 or3) and build a ISP programmer yourself which is simple and freely available on the internet.
mvs sarma said:srikanthsamaga said:Just reading Mazidi book is not enough, you should practice the examples given in that practically, and then write small and simple codes on your own.
well said Srikant !!perfect advise.
as any way you are able to write in Keil, better continue. while compiling, you can get .hex and even .asmsalman said:Hi friends, can someone tell me which language is best for programming?
and tell me the software through which i burn my 89c51??
and what is assembler??i write programs in Keil uversion 3.
thank u
Yes i do agree with this...as Kenith's book is also included as a syllabus in Indian engineering courses as a text book.luv said:you can start from Kenneth J. Ayala...........
