8051 MCU - GSM communication
Ramche
Newbie level 1
I'm working on a project about remote controlled house (home automation). This is for my capstone project which I'm working on.:smile:
I want to send SMS messages from my mobile phone to a Telit GM862 GSM device and those messages need to pass throw UART to a 8051 microcontroller (Atmel AT89S8253). The microcontroller needs to understand them as commands and it needs to switch on or off some relays.
I have an exaple program which is made by MikroElektronika, and its goal is to display some basic functions of the GSM module like making and answering a call and hanging up. I installed this program on the microcontroller, and it worked.
I have no experience with C, so I need someone to help me for better understanding how works this code, and what I have to modify on this code to reach my goal?:roll:
The code is like:
// LCD module connections
sbit LCD_RS at P2_0_bit;
sbit LCD_EN at P2_1_bit;
sbit LCD_D4 at P2_2_bit;
sbit LCD_D5 at P2_3_bit;
sbit LCD_D6 at P2_4_bit;
sbit LCD_D7 at P2_5_bit;
// End LCD module connections
// set of AT commands
const char atc1[] = "ATE0";                      // disable echo
const char atc2[] = "AT# CAP= 1";                // enables handsfree external mic/ear audio path
const char atc3[] = "ATD123456789;";             // place a call to phone number 123456789
                                                 // instead of 123456789 insert your phone number
const char atc4[] = "ATH";                       // hang up
const char atc5[] = "ATA";                       // answer a call
const char atc6[] = "AT#HFMICG=4";               // handsfree microphone gain
const char atc7[] = "AT#SHFEC=1";                // handsfree echo canceller
const char atc8[] = "AT+CLVL=12";                // loudspeaker volume level
const char atc9[] = "AT#SRS= 3,0";               // select ringer sound
const char atc10[] = "ATS0=0";                   // number of rings to auto answer (auto answer disabled)
// lcd interface messages
const LCD_MESSAGE_LENGTH = 16;
const char lcd1[] = "Initializing...";
const char lcd2[] = "Power-Up GSM!!!";
const char lcd3[] = "P0.3-Continue";
const char lcd4[] = "Ready! P0.0-Dial";
const char lcd5[] = "P0.1-HG P0.2-AW";
const char lcd6[] = "Calling...";
const char lcd7[] = "Hanging Up!";
const char lcd8[] = "Answering!";
const char lcd9[] = "RING!!!";
// responses to parse
const GSM_OK    = 0;
const GSM_RING  = 1;
char gsm_state = 0;
char response_rcvd = 0;
short responseID = -1, response = -1;
char msg[LCD_MESSAGE_LENGTH+1];
// copy const to ram string
char * CopyConst2Ram(char * dest, const char * src){
char * d ;
 d = dest;
 for(;*dest++ = *src++;)
 return d;
// uart rx interrupt handler
void interrupt() org IVT_ADDR_ES {
char tmp;
  EA_bit = 0;                                    // Clear global interrupt enable flag
  if (RI_bit) {                                  // do we have uart rx interrupt request?
    tmp = UART1_Read();                          // get received byte
// process reception through state machine
// we are parsing only "OK" and "RING" responses
    switch (gsm_state) {
      case  0: {
                response = -1;                   // clear response
                if (tmp == 'O')                  // we have 'O', it could be "OK"
                  gsm_state = 1;                 // expecting 'K'
                if (tmp == 'R')                  // we have 'R', it could be "RING"
                  gsm_state = 10;                // expecting 'I'
                break;
      case  1: {
                if (tmp == 'K') {                // we have 'K' ->
                  response = GSM_OK;             // we have "OK" response
                  gsm_state = 50;                // expecting CR+LF
                else
                  gsm_state = 0;                 // reset state machine
                break;
      case 10: {
                if (tmp == 'I')                  // we have 'I', it could be "RING"
                  gsm_state = 11;                // expecting 'N'
                else
                break;
      case 11: {
                if (tmp == 'N')                  // we have 'N', it could be "RING"
                  gsm_state = 12;                // expecting 'G'
                else
                break;
      case 12: {
                if (tmp == 'G') {                // we have 'G' ->
                  response = GSM_RING;           // we have "RING" response
                else
                break;
      case 50: {
                if (tmp == 13)                   // we have 13, it could be CR+LF
                  gsm_state = 51;                // expecting LF
                else
                break;
      case 51: {
                if (tmp == 10) {                 // we have LF, response is complete
                  response_rcvd = 1;             // set reception flag
                  responseID = response;         // set response ID
                break;
      default: {                                 // unwanted character
                break;
       RI_bit = 0;                               // clear UART interrupt flag
    EA_bit = 1;                                  // Set global interrupt enable flag
// send ATC command
void send_atc(const char *s)
// send command string
   while(*s) {
      UART1_Write(*s++);
// terminate command with CR
   UART1_Write(0x0D);
// get GSM response, if there is any
short get_response() {
  if (response_rcvd) {
    response_rcvd = 0;
    return responseID;
  else
    return -1;
// wait for GSM response: OK
void wait_GSM_OK() {
 while (get_response() != GSM_OK);
// pause
void wait() {
  Delay_ms(1000);
void main() {
  P1_0_bit = 1;
  UART1_Init(4800);                    // initialize UART1 module
  Delay_ms(100);
// set RTS pin to zero, we will use only RX i TX
  P3_3_bit = 0;
  ES_bit = 1;                          // enable UART interrupt
  RI_bit = 0;                          // clear UART RX interrupt flag
  EA_bit = 1;                          // enable interrupts
// setup lcd module
  Lcd_Init();
  Lcd_Cmd(_LCD_CURSOR_OFF);
// LCD_Out: power-up gsm
  LCD_Out(1,1,CopyConst2Ram(msg,lcd2));
  LCD_Out(2,1,CopyConst2Ram(msg,lcd3));
// wait for start
  while(P0_3_bit)
  Lcd_Cmd(_LCD_CLEAR);
// LCD_Out: Initializing...
  LCD_Out(1,1,CopyConst2Ram(msg,lcd1));
  Delay_ms(2000);                                // wait for the GSM module to initialize it self
// negotiate baud rate
  while(1) {
    send_atc("AT");                              // send "AT" string until gsm sets up its baud rade
    Delay_ms(100);                               // and gets it correctly
    if (get_response() == GSM_OK)                // if gsm says "OK" on our baud rate we got it
      break;
// disable command echo
   send_atc(atc1);
   wait_GSM_OK();
// change audio path (enables handsfree external mic/ear audio path)
   send_atc(atc2);
   wait_GSM_OK();
   send_atc(atc6);
   wait_GSM_OK();
   send_atc(atc7);
   wait_GSM_OK();
   send_atc(atc8);
   wait_GSM_OK();
   send_atc(atc9);
   wait_GSM_OK();
   send_atc(atc10);
   wait_GSM_OK();
  while(1) {
// LCD_Out: Ready! P0.0-Dial
    LCD_Out(1,1,CopyConst2Ram(msg,lcd4));
// LCD_Out: P0.1-HNG P0.2-ASW
    LCD_Out(2,1,CopyConst2Ram(msg,lcd5));
    if(!P0_0_bit) {
// LCD_Out: Calling...
      LCD_Out(1,1,CopyConst2Ram(msg,lcd6));
// mobile originated call to specified number
      send_atc(atc3);
      wait_GSM_OK();
    if(!P0_1_bit) {
// disconnect existing connection
      send_atc(atc4);
      wait_GSM_OK();
// LCD_Out: Hanging Up!
      LCD_Out(1,1,CopyConst2Ram(msg,lcd7));
      wait();
    if(!P0_2_bit) {
// answer a call
      send_atc(atc5);
      wait_GSM_OK();
// LCD_Out: Answering!
      LCD_Out(1,1,CopyConst2Ram(msg,lcd8));
      wait();
// process gsm response
      response_rcvd = 0;                         // clear response received flag
      switch (responseID) {
        case GSM_OK   : break;                   // do nothing
        case GSM_RING : {
                        // LCD_Out:RING!!!
                          LCD_Out(1,1,CopyConst2Ram(msg,lcd9));
                          wait();
        default  : {
                                                 // process illegal responses
Follow the comments given in the code to modify it (additionally study the comments where you find this codes)
Try to start coding for small interfacing circuits, such that blinking LED to get some hands on experience in C language
