8051 external interrupt problem
0killingsoul0
Junior Member level 2
View attachment one.bmpHi all. I am getting a weird type of error.Its a simle code to count the interrupts in ten second. When i physically implement the circuit on bread board , its counting more low level signals ( grounding the pin 3.2) . Like if i ground it once it should count/display one but its displaying larger value. This code is working perfectly on proteus and on trainer kit. But dont know what i am missing in circuit its not working.
View attachment one.rar
 				 		   // Program to interface single seven segment
#include<reg51.h>
 char num[]={0x40,0xF9,0x24,0x30,0x19,0x12,0x02,0xF8,0x00,0x10};		// Hex values corresponding to digits 0 to 9
unsigned int counter;
unsigned int counter1;
unsigned int counter2;
unsigned int counter3;
unsigned int counter4;
delay_ms(int time)		// Time delay function
	int i,j;
 	for(i=0;i<time;i++)
  	for(j=0;j<1275;j++);
 ////////////// iNTERUPT tO cOUNT
void ex0_isr (void) interrupt 0
	counter++;   // Increment the count
void countdelay(void)
	TMOD=0x01;
	TL0=0x00;
	TH0=0x00;
	TR0=1;
	while (TF0==0);
	TR0=0;
	TF0=0;
void main()
unsigned int c;
 IT0 = 1;   // Configure interrupt 0 for falling edge on /INT0 (P3.2)
	  EX0 = 1;   // Enable EX0 Interrupt
	  EA = 1;    // Enable Global Interrupt Flag
  //  counter=6709;
	P0=num[0];
		P1=num[0];
		P2=num[0];
	while(1)
			 for(c=0;c<154;c++)
		    countdelay();		 // 65.535 ms delay
		  counter1=counter%10;
		  counter2=(counter/10)%10;
	      counter3=(counter/100)%10;
     	P0=num[counter1];
		P1=num[counter2];
		P2=num[counter3];
		counter=0;
could you post the trainer kit you were using? (if you have an schematic, post it too) as it seems a bit more complex than your simple push button...
in simulation this will work with no flaws, but in a real implementation the bouncing and debouncing of the push button WILL ALWAYS produce extra pulses for the microcontroller.
there you implement a debouncing circuit.
you could search more, but the one i used a lot is the **broken link removed** as it will do the job.
now, maybe you can improve a little with an external pull-up for the push-button, something like 4k7 or 10k ohm,
otherwise you need to implement this in software, but it's a difficult task as you wanted to count via interrupt.
That's why me would like to see which development kit you used and worked...
Initial value for variable counter in main program should be set to 0. ie. counter=0; . Tq.
