[8051]display negative temperature readings from sht1x
liovag
Newbie level 3
Newbie level 3
8051 assembly negative
[8051]how i can display in lcd negative temperature readings from sht1x with assembly language?
Added after 20 minutes:
I use 8051 microcontroller and one 20 x 2 lcd module for display temperature and humidity.
Works fine, but i don't know how to convert negative temperature readings for display on lcd. :cry:
Positive temperature readings displaying fine.
8051 negative
I have no idea about assembly... but if u can switch over to C language u can display negative temperature on LCD...
I have done it using sprintf function in my code...
temperature +8051
Thanks for reply!!
Finaly, i solve the problem. :D
sht1x
hey liovag can u please provide me ur circuit diagram of project ???...and PCB layout if u have...
thanx in advance
I don't know how i create circuit diagram or a PCB layout. I appreciate if you tell me how i create.
