8051 and 2 serial ports
DrWhoF
Advanced Member level 1
I need to connect 2 RS-232 devices to 87C52. This mcu has only one UART. How can I do it?
Thanks
DrWho
That depends on volume of data that will come/go from/to both RS-232 devices.
One option will be to connect the more important device to hardware UART (with serial port interrupt ON) and the other device to software UART (see Philips application notes for software UART, with INT0/1 ON).
You can also consider sharing the hardware UART (4 NAND gates + 1 mcu pin per RX or Tx) but this option will require some kind of synchronization.
Regards,
IanP
    DrWhoF
You can implement a software UART via bit-banging. Essentially, you use timer interrupts to synchronize data transfer to IO pins. A simple google search gave **broken link removed**.
    DrWhoF
1. periodic timer interrupt at a rate 4-32x higher than the baudrate.
+ fullduplex, even multichannel could be possible
+ does not require dedicated pin
+ under certain conditions can run from the same timer1 as the HW UART
- permanently occupies significant % of processor time
http://www.atmel.com/dyn/resources/prod_documents/doc3ab877f2ec329.pdf
2. receiver triggered by an edge-triggered external interrupt (special: a counter set to roll over on the first edge); then sampled using timer timed at baudrate.
Transmitter simply using timer at baudrate.
+ low software overhead
- dedicated (extint) pin needed for Rx
- fullduplex requires 2 timers
An implementation using PCA found in some 8051 derivatives:
http://www.intel.com/design/mcs51/applnots/270531.htm
3. only receiver or only transmitter by performing the sampling in a loop in main program
+ simple
- only 1 direction
- uses up 100% of processor time
- virtually excludes using other interrupts simultaneously
wek
try W77e58 or uPSD from ST
