8 point fft using ipcore
Sharmi703@gmail.com
Newbie level 1
Hi i have designed 8 point fft v7.1 using logicore 12.3... simulation is done.. but my output is full zero... the input which i m giving its taking....pls any1 help me..
My testbench code
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
module tb;
always
begin
clk =1;
#10;
clk =0;
#10;
end
    // Inputs
    reg clk;
    reg start;
    reg [31:0] xn_re;
    reg [31:0] xn_im;
    reg fwd_inv;
    reg fwd_inv_we;
    // Outputs
    wire rfd;
    wire [2:0] xn_index;
    wire busy;
    wire edone;
    wire done;
    wire dv;
    wire [2:0] xk_index;
    wire [31:0] xk_re;
    wire [31:0] xk_im;
    // Instantiate the Unit Under Test (UUT)
    fft1 uut (
        .clk(clk),
        .start(start),
        .xn_re(xn_re),
        .xn_im(xn_im),
        .fwd_inv(fwd_inv),
        .fwd_inv_we(fwd_inv_we),
        .rfd(rfd),
        .xn_index(xn_index),
        .busy(busy),
        .edone(edone),
        .done(done),
        .dv(dv),
        .xk_index(xk_index),
        .xk_re(xk_re),
        .xk_im(xk_im)
    initial begin
        // Initialize Inputs
        clk = 0;
        start = 0;
        xn_re = 0;
        xn_im = 0;
        fwd_inv = 0;
        fwd_inv_we = 0;
        // Wait 100 ns for global reset to finish
        #100;
        start = 1;
        fwd_inv = 1;
        fwd_inv_we = 0;
        // Add stimulus here
       //#20;
        xn_re = 32'b01000000000000000000000000000000; // 2
      xn_im = 0;
        #20;
        xn_re = 32'b01000000100000000000000000000000; //------ 4
        xn_im = 0;
        //#20;
        //xn_re = 32'b01000000111000000000000000000000; //------ 7
        //xn_im = 0;
        //#20;
        //xn_re = 32'b01000001000100000000000000000000; //------9
        //xn_im = 0;
       //#20;
        //xn_re = 32'b01000000010000000000000000000000; //------ 3
        //xn_im = 0;
        //#20;
        //xn_re = 32'b01000001001000000000000000000000; //------ 10
        //xn_im = 0;
      //#20;
      //xn_re = 32'b01000001010000000000000000000000; //------ 12
        //xn_im = 0;
     // #20;
      //xn_re = 32'b01000001011100000000000000000000; //------ 15
        //xn_im = 0;
    end
endmodule
Main module
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
module fft1(clk,start,xn_re,xn_im,fwd_inv,fwd_inv_we,rfd,xn_index,busy,edone,done,dv,xk_index,xk_re,xk_im);
input [31:0] xn_re,xn_im;
input clk,start,fwd_inv,fwd_inv_we;
output [31:0] xk_re,xk_im;
output [2:0] xn_index,xk_index;
output rfd,busy,done,edone,dv;
reg ce=1,sclr=0;
wire [31:0] xk_re,xk_im;
fft1_ip a1(
  .clk(clk),
  .start(start),
  .ce(ce),
  .sclr(sclr),
  .xn_re(xn_re),
  .xn_im(xn_im),
  .fwd_inv(fwd_inv),
  .rfd(rfd),
  .busy(busy),
  .edone(edone),
  .done(done),
  .dv(dv),
  .xk_re(xk_re),
  .xk_im(xk_im)
endmodule
