8 channel IR remote using PIC
your1click
Member level 3
Member level 3
Dubai, United Arab Emirates, United Arab Emirates
Dear friend,
So i want to replace that IR and I want to connect direct from wire like this.test.JPG, please check attached file also here I upload code also,
I tried to check from Proteus its not working so please help me....
thanks in advance
  • ir_rx.zip
hello
on transmitter
when you applya 1 logic level on RC4 to active the IR led1 trough the transistor,
T1 is ON, so level across collector is 0V so => 0 logic level
you connect it direct to RA3 input on Receiver
so you have maybe to reverse the logic level !
or try a direct link RC4 transmitter to RA3 Receiver .. with a pull up resistor on RC4
hello,
if IR link with a TSOP1738 as receiver ,you have a "porteuse" carrier frequency of 38 khz
emitted by the transmiter,,
wich is eliminated by the IR receiver !
you can't use direct link without modify the software on each side.!
Another way could be to use soft Uart link.
